DCS
Last activity: 19 Feb 2021 11:09 EST
ADM - Symbolic predictor binning issue
Hi Team,
We have ADM implementation in one of our usecase. We have seen our ADM is not performing compare to the business rules for certain use cases and when we debug the root cause we found a weird issue associated with how symbolic predictors are getting Binned impacting the ADM prediction. For example: a predictor "Reason" has 3 Bin's as per the attached screen print. Bin1 : REFAN, SRLTE, SERREP, TERMSFEES Bin2 : MISSING Bin3 : NON-MISSING
From the example it classified Missing and Non-Missing as key values for predictors rather than Binning the other sets of values in Bin1 (we are expecting higher response for Bin1).
Current ADM Settings:
Data analysis binning
- Grouping granularity: 0.25
- Grouping minimum cases: 0.05
Predictor selection
- Activate predictors with a performance above:0.52
- Group predictors with a correlation above:0.8
We are expecting each symbol to be kept in a separate Bin to make the grouping of symbolic predictor more meaningful. Anyone come across the similar issue & what are the additional settings needed? We are planning to update "Grouping granularity from 0.25 to 0.9 and "Group predictors with a correlation above" from 0.8 to 0.95
