ABC
Last activity: 21 Dec 2020 9:24 EST
Real time Event Triggered from Postman says Connect Timed Out
Im trying to trigger a realtime event using postman sample request with calldetailsrecord pega exercise.
I created a stream data set and configured it in the data flow and calls the event strategy from stream dataset. While all the configuration was done correctly and outputed till event streategy in the data flow
But once im trying to hit postman with POST action passing the sample request with correct parameters
im always getting connect timed out.
Eventhough i created a realtime data flow run and its in progress still im getting the same error.
