Traditional UI in Constellation (Blended UI) landing pages fail to load for business users in Production with an HTTP 400 Bad Request error, while administrators are unaffected. This article explains the…
Issue Export to Excel from Constellation list Views and reports generates files containing only headers and no rows when data pages use queryable Data Pages with dynamic filter conditions. Symptoms and…
Issue When a table is configured using an Embedded List as its data source, the Search icon functionality does not return results. Entering a valid search term causes the table to display zero rows…
Charts failed to render after upgrade to Pega Platform 26.1.0 in a Traditional UI / UI Kit application. Root cause is a JavaScript conflict introduced by the AppDynamics ADRUM agent, which overrides the…
Executive Summary - Action Required Pega regularly implements security controls designed to safeguard client environments. As part of these efforts, Pega will release patch updates and hotfixes addressing…
Issue After updating to Pega Infinity™ '25.1.1, outbound HTML correspondence emails that use tags within HTML attributes, using supported correspondence fragment patterns instead. References…
Issue A multi-Select Data Reference property does not persist when saving a Data Record via savable Data Page in Pega Constellation. Symptoms and Impact When using a Data Reference control configured…
Issue After updating from an earlier version of Pega Platform™ to 26.1, users entering values into the OOB password fields pyPwdNew and pyPwdConfirmText on a Change Password form find that the entered…
Projected Search changes in 2026 The following changes are anticipated in upcoming releases during the 2026 calendar year: Elasticsearch 9 and OpenSearch 3 support Red Hat Enterprise Linux 10 support…
Issue Platform error occurs on logging off and relogging into the Work portal on Pega Infinity™ ‘26.1.1. When logging off and subsequently logging back into the Work portal from the Launch portal, a ‘…
Read More
0
We'd prefer it if you saw us at our best.
