TD
Last activity: 14 Sep 2020 11:48 EDT
Ability for user to update the static content in Paragraph and store that HTML para in DB table
After successfully using paragraph rule and using them in creating pdf i have got another requirements for allowing the user the update the static content on the paragraph. That way technology dont have to involve to make any static changes. Once the user update the static content from the portal system should always pick the updated paragraph to create a pdf.
I am thinking if is there is anyway we can store the entire HTML of Paragraph in column of a database table? That way if user make any updates the updated HTML will get added to table as a new record. That way system can refer both the old record as well as new record as per the requirements. Because system needs to refer both the old version paragraphs as well as new version paragraphs.
Can you please provide your thoughts?
