How to generate PDF documents using custom fonts
How to use custom fonts in Pega paragraph rules and activity for generating PDF
I found quite time consuming to install custom fonts and use those for generating a pdf document through the HtmlToPdf activity, therefore I decided to share the steps for achieving that. The solution has been tested on Pega 8.1 which uses P4DML version 3100.PRPC1 Pro.
The high levels steps are:
- Enable logging by setting the PdfUtilImpl logger to DEBUG
- Install custom fonts
- Define CCS stylesheet
- Create an HTML rule to be passed to the HtmlToPDF activity for rendering the Html stream
- Set Dynamic System Settings for Fonts and Props folders [optional]
- Create a test activity to generate the PDF document through the HtmlToPDF OOB activity
Detailed instructions are described in the attached document. Hope you find it useful.
***Edited by Moderator Marissa to change Type from General to Product; update Platform Capability tags; add Developer Knowledge Share tag****
