OOTB function to get only 2 values after the decimal
Do we have any OOTB function to get only 2 values after the decimal.
Eg:12345.6789-input
Output:12345.67
Need to set in request DT not in UI
Did you miss our WEBINAR: Transform IT & Operations with AI: Pega Blueprint Advantage? Watch the REPLAY!
This webinar will show how AI is revolutionizing these functions and how Pega’s Blueprint Solution can help you fully leverage AI to meet your goals.
Pega Cloud status shows the overall health of Pega Cloud products and services, by region.
Manage your subscriptions by clicking the Subscribe To Updates button. Check out our Support document for more information: Pega Cloud Status
Eg:12345.6789-input
Output:12345.67
Hi Sam,
Can you please try the workaround mentioned in below link to see if its solves your requirement
https://collaborate.pega.com/question/truncating-decimal-places-without-doing-rounding
Hi
Try with below example you will two digits after decimal point
Substring(whatcomeafterfirst(12.23,’.’),0,2)
output is 23
whatcomebeforefirst(12.23,’.’)
output is 12
then
concatenate both Output
