Privilege Inheritance
Can someone help me understand the usage of Privilege inheritance option within an access role as I couldn't see difference with or without that option checked.
For instance, Even with Privilege inheritance unchecked the worktype classes of an application inherit access settings from Work- if explicit AROs are not defined for worktypes and current access group is dependent on OOTB access roles. Then what difference does it make with this option checked.
Any suggestions are appreciated.
Satish
