ai4process
PL
Last activity: 18 Aug 2020 6:10 EDT
SOAP XML outgoing message auto converted
Hello
I have the following problem with SOAP XML message which is sent to the external system from Pega.
My SOAP connector uses XML message which is streamed in a activity and passed as a clipboard property to SOAP connect. Stream rule is configured in the way that it generates a self-closing node (<node/>) if there is nothing to be included inside.
And the problem, for some reason my message gets converted from <node/> to <node></node> somewhere during soap envelope creation in InvokeAxis2 activity.
What I did for testing - in InvokeAxis2 activity (Pega-IntegrationEngine:07-10-33) in step #13 around line 213 I logged value of 'paramVal' property and it contains the correct value of my message (<node/>).
When I log complete envelope message around line 330 (property soapEnvelope) I can see that my node is converted to <node></node>.
And the question here is, is there any DSS or other global setting which can impact such XML conversion?
This is happening in the Client's internal environment. I did a similar test in our clean lab system and all looks to be fine. So i presume that there must be some setting/DSS/hotfix which impacts this?
