SSA
Last activity: 13 Aug 2020 8:56 EDT
Question on Authentication Service Basic Authentication using externally stored credentials ver826
Hi Experts,
Pega Platform version 8.2.6
I created the Authentication Service based on the basic credentials authentication type. We have the option to check "Verify credentials using external identity store" we are using the data page and validating the credentials using the external DB. if the credentials are right we are setting pyApprovalStatus==true everything works fine but if the credentials are wrong how to display the message on the login screen is not working
No proper help/example/document on how to handle failure scenarios. username wrong or password wrong
if we add the security policies on the captcha/password/lock works with platform authentication but not above scenario?
workaround tried: setting pyChallenge and pyFailMessage but not working.
Appreciate all your help.
***Edited by Moderator: Pallavi to change content type from Discussion to Question, move from Pega Academy to Product***
