Impossible to set set-max-map-count variable for pod pega-search
We deploy PEGA 8.3 on our private cloud.
Sometimes our peagasearch pods don't start. On log we can see
[2020-08-04T13:08:10,196][INFO ][o.e.b.BootstrapChecks ] [MWNgsmz] bound or publishing to a non-loopback address, enforcing bootstrap checks ERROR: [1] bootstrap checks failed [1]: max virtual memory areas vm.max_map_count [65530] is too low, increase to at least [262144]
For information we work on privileged access system that mean I can't modify the init container to change the value.
After reading the documentation I try to set-max-map-count directly on the pod with this command
sysctl -w vm.max_map_count=262144
https://www.elastic.co/guide/en/elasticsearch/reference/current/vm-max-map-count.html
but I have the error
sysctl: setting key "vm.max_map_count": Read-only file system
How to modify this value?
The documentation https://community.pega.com/knowledgebase/articles/client-managed-cloud/cloud/meeting-requirements-and-prerequisites
The Pega Platform search service uses Elasticsearch, which uses an mmapfs directory by default for 64-bit systems to store its indices (for more information, see the Elastic document, Virtual Memory. To increase the mmap count on your environment, do one of the following:
- Update the
vm.max_map_countsetting in/etc/sysctl.confon your nodes and set the valuevm.max_map_count=262144. - Utilize the
set-max-map-countinitContainer in the example yaml file to automatically configure the setting. If you choose this method, note that the init container runs in privileged mode, so you must verify that your environment allows privileged containers.
