WIPRO
Last activity: 26 Jul 2020 20:05 EDT
How to compare and understand the Kubernetes deployment model with Pre 8.2
Hi
I am new to containerization and kubernetes. I have the following basic questions. If someone can clarify, that will be helpful for myself and many others. As I am talking to the many in the community, not many have a clear view.
Assumption: Version - 8.4.1, Server - Tomcat, Database - Postgres, Cloud - Azure
1. Can I compare JVM or node in the pre 8.2 to a POD?
2. When I want to deploy a RAP, can I just use prpcUtils or should I create a new docker image?
3. Can all PODs talk to each other? Assume I deploy a RAP into one of the PODs, does system pulse updates the every other POD and its cache?
4. When I want to horizontally auto scale a batch POD where my advanced agent is running which I want to run only in one POD (to avoid object contention), how that can be achieved without manual intervention?
5. Where do we specify JVM configuration for k8s nodes?
6. What normally differs in the CI/CD pipeline set-up when it involves k8s (AKS)
Most of the documentation I can see are for PEGA installation but not for deploying a RAP. If someone can help answering the above, it will be helpful.
