Virtual Page Lists do not support this method (Data Transform)
I'm trying to look into the current application Work classes to check if a class already exists before assigning it to a case, like using Dynamic Class Referencing (DCR). I found ootb Data page D_AllClassesInApp contains this information, but when trying the below When rule it results in an error:
Also using an expression like this results in the same error:
@IsInPageList(Param.CountryClass, .pyClassName, D_AllClassesInApp.pxResults)
Error: "Virtual Page Lists do not support this method"
Since I'm not trying to edit the items of the Page list, I don't understand why this approach is not supported...
Also any thoughts on work-around approaches are welcome.
-Jose
