Bypass login on pega web mash up working on dev, but not working on production level
Hi my mash up apps keep on getting unaunthenticated error on node with production level 5, but not having issue on node level 2 .
This is how my html code :
<script src ='https://hcc.sinarmas.co.id/prweb/IAC/?pyActivity=pzIncludeMashupScripts'></script>
<script>
var link = document.URL;
var url = new URL(link);
var CompanyCode = url.searchParams.get("co");
var div;
var txt;
var txt2 = "<div data-pega-gadgetname ='PegaGadget' ";
var txt4 = " data-pega-action ='createNewWork' ";
var txt5 = " data-pega-action-param-classname ='ASM-HCC-Work-JobFair' ";
var txt6 = " data-pega-action-param-flowname ='pyStartCase' ";
var txt7 = " data-pega-action-param-model ='' ";
var txt8 = " data-pega-isdeferloaded ='false' ";
var txt9 = " data-pega-applicationname ='HCC' ";
var txt10 = " data-pega-threadname ='STANDARD' ";
var txt11 = " data-pega-systemid ='pega'";
var txt12 = " data-pega-url ='https://hcc.sinarmas.co.id/prweb/IAC/' ";
var txt13 = " data-pega-redirectguests ='true'";
var txt14 = " data-pega-action-param-parameters='{\"UserIdentifier\":\"Recruitment\",\"CompanyCode\":\"KBRU\"}'";
var txt15 = "></div>";
txt = txt2.concat(txt4, txt5, txt6, txt7, txt8, txt9, txt10, txt11, txt12, txt13, txt14, txt15);
document.write(txt);
</script>
is there something missing here ?
