Pega Startup logs showing WARN create a Data-Admin-DB-Name definition
After Upgrading from 6.2 to 7.4, Server restart is throwing different Warnings.
How to resolve this issue?
Using new Connection Manager for database "pegarules"
2020-07-09 19:04:39,689 [ocalhost-startStop-1] [ ] [ ] [ ] (l.store.ConnectionBrokerPolicy) INFO - Using new Connection Manager for database "pegadata"
2020-07-09 19:04:39,690 [ocalhost-startStop-1] [ ] [ ] [ ] (dbms.JdbcConnectionManagerImpl) WARN - The database pegarules is only defined in the bootstrap configuration; create a Data-Admin-DB-Name definition
2020-07-09 19:04:39,690 [ocalhost-startStop-1] [ ] [ ] [ ] (dbms.JdbcConnectionManagerImpl) WARN - The database pegadata is only defined in the bootstrap configuration; create a Data-Admin-DB-Name definition
