TCS
Last activity: 30 Apr 2021 17:09 EDT
Batch processing in BIX
In our project, we are using BIX for the purpose of copying data from Pega DB to another DB using extract rules. Bix supports the data to be copied in the form of batches (Pega defaults provides 30 records at a time to commit to the target DB). During this process, some times data fails to copy and if any record fails, total batch gets failed and moves to next batch. Failed batch details are found in the BIX logs and here i need know is there any process to run record by record for the failed cases in a batch, so that we can identify the exact reord which is failing to update to the target DB and can fix the issue.
***Edited by Moderator Kayla to update Platform Capability tags****
