Bulk operator enabled
Hi
I am required to enable many operator at one time.
Is there any standard activity to make bulk operators enabled?
Hi
You can enable operators in bulk from the Operator Access window.
To access that, Go to Org & Security > Authentication > Operator Access from the Configuration Menu.
If you need an activity for this, you can trace and find out the activity used in this operation behind by Pega, and then you can save as & customize to your need.
Let me know if you have any queries on the above.
Good Luck!
Can you elaborate more?
Do you want to create operator id in bulk?
