Need to know how to use an XML file for SOAP integration in Pega 8.1.3
We have an XML file embedded in SOAP env format. This will create a ticket in our integration environment when its api is called via SOAP. However, when I was trying to create a SOAP integration thorough the wizard, it was asking for WSDL file.
Is there any way that XML file can be used for creating SOAP integration?
If XML file cannot be used, is there any way to convert the XML to WSDL format in Pega?
Manju.
