Edit Input apart from property advanced tab
Is there another way to refer Edit Input apart from the property advanced tab?
Can you tell us a bit more about your requirement?
PFB kind of,(Copied)
Consider in my application I am having class structure as @baseClass , A- , A-B- , A-B-C , A-B-C-Work ,
A-B-C-Work-BirthRegistration. I am having one property 'FatherName' at A-B-C level. Now I am defining a case type at A-B-C-Work-BirthRegistration. In case type on the first screen, while entering Father's name, I have a requirement that "If the Father's name doesn't ends with Mr. then I need to add suffix as Mr.". I am trying to achieve this by using 'Edit Input'. I have written the java code for this inside Edit-Input.
Here only the problem comes. If i refer the same Edit Input in the advanced tab of property definition, It will be applicable throughout the application. That is not the expectation.
Because my application may have another case type 'Land registration' defined at
A-B-C-Work-LandRegistration, in which the suffix Mr. needs not be added. So now I can achieve this requirement/handle this issue?
