Pega-SearchEngine DSS settings are overwritten and reset to default values Pega 8.1.2
The settings are associated with the Pega-SearchEngine ruleset and have a purpose prefixed with indexing/distributed/* Examples are:
Pega-SearchEngine • indexing/distributed/index_enabled = false
Steps to Reproduce
- Change one or several of the affected DSS using Designer Studio. For example, set Pega-SearchEngine • indexing/distributed/index_enabled as false
- Restart the application server
- Check the DSS setting. It is reset to the default setting of true
As per a article we have updated one more DSS to Set the below DSS to skip bootstrapping but the resolution not worked for us.
Pega-SearchEngine * indexing/distributed/autonodecleanupandreindex = false
