Private edit button is not visible
Usually, if below conditions are met, Private edit button should be available even if the ruleset is locked.
- "Allow rule checkout" in "Security" tab of operator record is checked
- "Use check-out?" in "Security" tab of ruleset record is checked
- Access Group of user has "pxAllowPrivateCheckout" privilege
If Developer A login using default authentication, Developer A is able to private edit the rules in locked ruleset.
If Developer B login using custom authentication, Developer B does not see "Private edit" button, hence developer B cannot private edit the rules in locked ruleset.
Is there anything I need to consider in order to allow private edit, when using custom authentication? It might not be because of authentication, but this is only the difference I see until this point.
