Verizon
Last activity: 20 Apr 2020 6:20 EDT
Case access from other pega application from Same DB, not in Built on applications
we have scenario to get data from the case created in other pega application not in our stack but in Same DB
Option 1 :- Get case API
Option 2 :- Make that other application in my app stack as built on (DCR)
Option 3:- Building some component in Shared ruleset similar to get case as internal
All the option are possible with some pro and cons.
The applications are unrelated I cannot make it as built on and get case API is using int / network layer its costly for internal. Option 3 is somewhat lean toward
Any other options are welcome here and highly appreciated
