CBA
Pickers radio button
I am trying to use OOTB Radio button option 8.3 from pickers in the section, by default three radio buttons are reflecting how to edit based on the retirement as a requirement I need only two radio options how to edit the ootb one. PFA
Updated: 14 Jun 2021 7:38 EDT
In the OOTB radio buttons property it is mentioned to show 3 options. "pyTemplateRadioButton" property has a local list and you can save as the property in your application and remove one from local list to meet your requirements.
It shows 3 options for the radio button while configuring it in section, but when you give the list source then only those many options will be shown. If there are 2 options present in the list then 2 options will be shown.
CBA
Thanks for the reply, I am aware of the list.
Is there any feasibility to make changes in OOTB one
Do you mean whenever we add the radio button control to the section, then you want to see 2 options?
CBA
Yeah, that's correct understanding, why by default 3 are given?
Sam mk
Updated: 19 Apr 2020 7:07 EDT
Hi Sam,
By default OOTB 8.3 ,for the radio button it shows 3 options in design time.
However,when the actual section loads on the browser it is displaying only two options .
I have tested in-house for a Boolean property.
CBA
Thanks for the reply...!
My query is regarding the radio buttons- by default when 3 radio buttons are reflecting, s there any possibility to make it as 2 and refer property later.
I can see option vertical/horizontal display and we can give numeric value for the display
