Lloyds Banking Group PLC
Property values in audit tab are not automatically decrpted - Field level auditing
I have encrypted a property value using the property encrypt access control policy (Underlying - used the data encryption with Platform cipher + AWS key ). The property value is automatically decrypted while showing on UI but not in Audit tab. Help says the values will be automatically - If no PropertyRead policy obfuscates the property, then the decrypted property value is visible to the user in a UI control.
Q1 )Can some one help why the decrypted value is not shown in Audit tab. Also how to achieve the same. ?
Also I have created the PropertyRead access control policy to show the masked value / clear value based on access control policy condition. I am able to achieve the same on UI but not on audit tab.
Q2) If the above is true does it mean access control policy condition's not applicable to data we show on audit tab?
Thank You, Surendra.PV
