Vodafone
how can we call the result of RDb List in data page
***Edited by Moderator Marissa to change type from Pega Academy to General; update Platform Capability Tags***
Updated: 14 Jun 2021 7:38 EDT
We can give the source of Data page as activity and get the RDB list in the activity.
Vodafone
Yes I did that,
But the data page does not show TempPage.pxResults when I run it.
Please check attached screensHOT AND SUGGEST
I could not open the above attachments, but if you are storing the RDB list results on TempPage. You can copy the results from TempPage.pxResults to Primary.pxResults in activity, then we get the results under DataPage.
Vodafone
Thank You , as suggested the result is coming
Vodafone
Again I want to call this data page in activity and populate values using data transform.
Shall I directly call data page and lke D_quoteDetail.pxResults(1).Country .... and set values.
Because whatever the values are retirned from Data Page I should set them in Data Transform.
pls suggest
In the same activity which is a source for the Data Page, we can copy the results to the Data page.
Please find the below screenshot for a sample implementation.
Vodafone
This is done. can you pls help on above question?
Yes, you can use like you mentioned above as per requirement.
