Dynamically change the file name in PDF Connector
I have an issue with the following scenario in Pega Robot Studio.
Scenario:
The user dynamically selects the file name for PDF Connector using a windows form. Then he performs a search for a keyword in that file.
This automation works fine.
Then, the user selects a different file for the second time. But when he performs the search again, it does not run.
Question:
Is it not possible to change the file in the PDF Connector according to my requirement? This will mean changing the file name multiple times and performing the search.
Note:
The same automation is run every time. A default file name is not given for the PDF connector.
I am using Pega Robot Studio 19.1
TIA
