Anthem Inc
Last activity: 16 Mar 2020 7:49 EDT
PRRuntime Exception
We are seeing PRRuntime Exception in production environment.
Rule: doUIAction, Class: @BASECLASS, Code: PRRuntime
Here is my analysis
As per my analysis from logs, null is being passed for one of the UI elements in PyActionLabelDisplaySection(PyCaseHeader section of call and authorization search cases) which could be the reason for PRRunTime exception.
Here is log file:
Here is my analysis
Here is log file:
2020-03-03 00:27:39,049 GMT*8*EXCP0001*0*0*va22pwppeg308_csx3p*NA*NA*HLBBTDS0C1SGQ9ES1ZUJ67IRC5BOG51OA*AXXXX*XXX-FW-CSFW-Work*XXXCSNCCSuper:00.00.00*XXX*N*115*HLBBTDS0C1SGQ9ES1ZUJ67IRC5BOG51OA*5385*https-jsse-nio2- Proprietary information hidden-8037-exec-41*TABTHREAD1*com.pega.pegarules.session.internal.mgmt.StreamBuilderTools*gbdcompass.corp.agp.ads| Proprietary information hidden*[email protected]*Rule-Obj-Activity:doUIAction*@BASECLASS PXCALLRETRIEVEREPORTDATA #20160923T103644.931 GMT Step: 6 Circum: 0*22****NA*NA*XXX-CS-NCC-Work-AuthorizationSearch*pyWorkPage*XXX-CS-NCC-Work-AuthorizationSearch*pyWorkPage*appendStream Rule-HTML-Section:pyActionLabelDisplaySection;appendStream Rule-HTML-Section:pyCaseHeader;appendStream Rule-HTML-Section:CaseActionArea;getStream Rule-HTML-Section:CPMPerformIncludes;getStream Rule-HTML-Harness:Perform;7 additional frames in stack;*NA*[MSG][Problem appending stream null][STACK][com.pega.pegarules.pub.PRRuntimeException: Section 'pyActionLabelDisplaySection' execution error on page 'pyWorkPage' of class 'XXX-CS-NCC-Work-AuthorizationSearch'. : null<CR><CR> at com.pegarules.generated.html_section.ra_stream_pyactionlabeldisplaysect
