ANZ
Last activity: 2 Mar 2020 19:27 EST
How to Save an object with Savable Data page ?
As with Obj-Save , how to use Savable Data page to save and object .
Approach I Followed : :
1.From activity used to Save-DataPage method to call a Savable Datapage , which takes string as parameter .
Passes the object as a string to that Savable Data page .
| Step 1 : Property-set in my activity - Setting the woject as a parameter |
| Param.WObject = "ActualWOObject" |
Step 2 : calling savable Data page with Parameter ObjectID and passing the parameter - Param.WObject in my activity Save-DataPage D_SaveWObject
ObjectID : Param.WObject"
Step 3 : Called a Data Transform from the Savable Datapage with a Parameter of type Page and send ObjectID .
With In Data transform , I am assigning the primary with my Param page
Data Transform : SaveWObject DT which is defined as a source in Data page Param : WObject of type Page
Steps :
Update Primary to Param.WObject |
Steps :
But this is not working and getting the error as Savable Data page has some errors which is not clearlt visible in the tracer .
But the clipboard has the error on the Savable Datapage -
- .pxInsName:Keys of Instance Value must be specified
