Tool for declare expression
While running a process, you notice that a read-only field on a form contains a value.
Which tool allows you to determine if a declare expression was used to calculate the value?
1) The Tracer
2) Clipboard tool
3) Declarative network
4) Live UI
Please explain. Thanks.
Hi Ganga,
The answer is the declarative network. Because you have noticed a read-only value was set to some value based on values entered in the form. You can quickly check the declarative network from the (Configure--->case management---->BusinessRules--->Declarative-network) for the current application and can find the destination value with the property name.
