Anthem
Anthem
Anthem
Posted: Feb 13, 2020
Last activity: Feb 13, 2020
Last activity: 13 Feb 2020 12:06 EST
Can Pega be used as the certificate store mechanism or Tomcat or both ?
Hi Team,
Could someone please suggest the best practice and explain if we have to use PEGA as the certificate store mechanism or Tomcat or both.
Thank you.
I would lean towards using Pega as the certificate store for the following reasons:
1. When you add/update certificates, server restart is not required.
2. Pega developers can manage the certificates as opposed to being dependent on the folks handling app server.
I see you tagged pega platform 7.3.1 so I'm assuming you are using pega 7.3.1. The only downside I see is if you have a large number of connectors, you will have to associate each connector with the keystore instance that contains your certificates. With Pega 8.3, this is no longer a requirement since there is the concept of platform truststore. Check this out: https://community.pega.com/knowledgebase/articles/whats-new-pega-platform/import-certificates-without-restarting-server-83
