How to refer Icon class in non-autogenerated rules .
we would like to display a icon in paragraph rule using Icon class.
Added below syntax to paragraph and it's working as long as keep the paragraph in source mode . it's getting cleared when source mode is off .
<i class="pi pi-help"> </i>
MLP 7.3.1
In general we add all html tags/styles in source mode, though they don't appear when we switch to normal mode in a paragraph rule form, they should be rendered during run-time.
Do you mean that once you uncheck source only mode check box (available in latest versions probably)in paragraph rule, the icon stops appearing in run-time? then that's weird.
You can probably post a screenshot and elaborate your problem if these inputs doesn't help.
-Shruthi
