Cognizant Technology Solutions India PVT Ltd
Posted: Jan 27, 2020
Last activity: Jan 27, 2020
Last activity: 27 Jan 2020 11:33 EST
Compatibility version of MQ
Hi Team,
Kindly provide information on the below points
- If MQ V9 is compatible for Pega 6, 7 and 8 Versions?
- MQ v9 is compatible for JDK Version 1.6,1.7 and 1.8?
- MQ v9 is compatible for WAS and OS?
If not, Kindly mention the versions which are compatible for Pega 6, 7 and 8 versions.
Ravi Kumar Reddy
<Removed>
***Moderator Edit-Vidyaranjan: Updated content to remove personal information***
Hi Ravi Kumar,
Below are the Pega compatibility with Java versions.
You can derive this information from Pega support guides for 6.x, 7.x and 8.x Versions.
Pega 6.1, 6.1 SP2, 6.2, 6.2 SP2, 6.3, 6.3 SP1 compatible with Sun/ Oracle Java 5, Java 6 and Java 7.
Pega 7.1 , 7.1.5, 7.1.6 compatible with Oracle Java 6.
Pega 7.1.7, 7.1.8, 7.1.9, 7.2, 7.2.1, 7.2.2, 7.3, 7.3.1 compatible with Oracle Java 7.
Pega 7.4, 8.1, 8.2 and 8.3 compatible with Java 7 and Java 8.
Regarding MQv9 compatibility with Java version please check: https://www.ibm.com/support/pages/mq-7x-mq-80-mq-90-and-mq-91-compatibility-previous-versions-including-usage-ccdt-files-jms-bindings-ssltls
Hope this information helps.
Warm regards,
Venkat
