John Deere
Last activity: 22 Jan 2020 1:57 EST
All cases assigned to manager and its reportees are not visible in manager worklist
As a part of requirement where a Manager's work list should show cases assigned to manager as well as its reportee I have written a report definition and called it on a Data Page through section.
on Section pagination has been enabled, however when I run the report definition it shows 500+ records correctly but on UI it is showing only 500 records.
On report definition in Data Access Tab the Maximum number of rows for export is set to 10000.
Is there any other setting with related to displaying records on UI ? if yes can we update it so that all records will get displayed ?
