Checking smart PDF check box
We need help to check the PDF check box is selected or not
I didn't get exactly your issue, can you please elaborate issue scenario? Are you not able to uncheck or what?
Are you trying to convey whether the value in the PDF uploaded or downloaded from the application has the values checked? Please elaborate your usecase to understand better.
Just needs to know how can be know in the automation weather the check box is checked or unchecked in PDF
