Can we use JDBC equivalent PreparedStatement in connect SQL for DB2 database.
The issue we are facing with Pega RDB-List is that we created a Connect-SQL with {ASIS:..} keyword to build a dynamic WHERE clause and executed the same query THOUSANDS of times by different threads with different value ( “PolicyNumber”) to fetch “Policy Details” from “External DB2 database”. As a result, the DB2 database receives thousands of SQLs and the SQLs are not closed. This causes performance issues. My questions are..
- Does Pega RDB-LIST .. {ASIS: keyword} use JDBC equivalent PreparedStatement ?
- When does JDBC connection in pega is released?
- Should we use a different connect-SQL to make use of JDBC PreparedStatement?
