Tooltip for label on column of table layout
Is tooltip functionality of label control on column of table layout dropped in v8.2 (recommended using smart info, not recommended tooltip by helper text)? I think I could configure it in v8.1.
I just want to make sure followings:
- Is the tooltip still availabel if I have already configured it on a label control in the older version?
- Should I do any modification, change it to smart info or helper text so on?
- What should I do if I want to display help text with hovering a label control on column of table layout if the tooltip is not available in/from v8.2?
