Independent
Last activity: 6 May 2020 7:09 EDT
Connect REST Connector - Auth Profile for Bearer Token obtained from JWT token Exchange
We need to call Rest API services that require a Bearer token in the authorization.
The Bearer token is returned from an authorization server using a OAuth2.0 JWT token exchange.
Is it possible to create an Authentication Profile to support this?
I.e., is it possible that I can specify the Authentication Profile in the Connect-REST rule, and the Bearer token is being taken care of through set up of OAuth 2.0 Provider data instances?
I noticed that JWT Bearer is a supported grant type in OAuth2.0 Client Registration. However, it is not an option for OAuth 2.0 Provider.
