EAI Systems
EAI Systems
SG
EAI Systems
Posted: Nov 5, 2019
Last activity: Nov 5, 2019
Last activity: 5 Nov 2019 10:25 EST
Facing issue while running ScenarioTests Task in Deployment manager pipeline
Hi Team,
We are trying to trigger pega Scenario tests task in Deployment Manager pipleline, but we are getting below error while running ScenarioTests Task.
"Java Exception: \torg.openqa.selenium.UnsupportedCommandException: Authorization required\nCommand duration or timeout: 229 milliseconds\nBuild info: version: 'unknown', revision: 'unknown', time: 'unknown'\nSystem info: host: 'ip-172-30-64-46', ip: ' Proprietary information hidden', os.name: 'Linux', os.arch: 'amd64', os.version: '4.14.128-87.105.amzn1.x86_64', java.version: '1.8.0_171'\nDriver info: org.openqa.selenium.remote.RemoteWebDriver"
As we have provided
a.In the Provider auth name field: Basic
b.In the Provider auth key field: Blank
And we are not sure about regarding two fields in configuring ScenarioTests Task in Pipeline
If the Test service provider is CrossBrowserTesting or BrowserStack or SauceLabs:
a. In the Provider auth name field: what exactly we need to provide here as we are trying to trigger our Pega scenario tests ?
b. In the Provider auth key field: what value we have to provide?
It will be helpful for us if you provide any document for executing E2E ScenarioTests in PDM pipeline , as we didn't get much information in Pega community support particular to this task.
We are on Pega clould 8.1.4V and Deployment manager 4.3 V
Srikanth
