TechMahindra
Last activity: 14 Nov 2019 8:44 EST
Unable to start process iexplore.exe. --Please provide a solution for this.
I am getting below error when I start debugging a simple message show automation.
Unable to start process iexplore.exe. Start process injected C:\Program Files\Internet Explorer\iexplore.exe failed
And got this below warning.
C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets(1820,5): warning MSB3245: Could not resolve this reference. Could not locate the assembly "Pega.IPC.Interop, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e". Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation errors.
Please help with a solution.
