Shield Consulting Solutions
Last activity: 28 Aug 2020 10:31 EDT
PRPC-8.2.2-354 - Operator:Unauthenticated or not available
New Installation of PRPC-8.2.2-354 using tomcat/docker. Unable to login to Pega platform using [email protected].
Error:
There has been an issue; please consult your system administrator
Status:fail
Node:No ID available
On Startup - see attachment for details
On Page reload - see attachment for details
com.pega.pegarules.pub.PRRuntimeException: Error including section 'pyChangePassword' on page 'pyOperPage' of class 'Data-Admin-Operator-ID'.
Caused by: java.lang.NoClassDefFoundError: java.awt.Toolkit
Updated: 28 Aug 2020 10:31 EDT
Kevin,
The pega docker container (below) seemed to work where the tomcat one had issues. Thank you very much for checking back on this thread.
https://hub.docker.com/r/pegasystems/pega
looks like your base tomcat image has some issues linking awt library, can you try this from pega: https://hub.docker.com/r/pegasystems/tomcat
Updated compose file with pegasystems/tomcat. Fired up a new instance on a new database install. Same result.On reload the page turns blank and the browser header says "Change Password". Logs attached.
version: '3.5'
services:
pega:
container_name: pega
#image: tomcat:latest
image: pegasystems/tomcat:latest
# docker image ls -a
REPOSITORY TAG IMAGE ID CREATED SIZE
pegasystems/tomcat latest fecdc4fdc13f 3 months ago 221MB
Interesting, if you only specify -DNodeType=WebUser, would the system come up fine?
Unfortunately, I am getting the same result even with "-DNodeType=WebUser" specified. The prweb.war file I am using is from the 116404_Pega_822.zip media.
# ps -ef | grep [N]odeType
root 1 0 99 13:24 ? 00:25:01 /opt/java/openjdk/bin/java -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.awt.headless=true -Xms4096m -Xmx8192m -Djava.security.egd=file:///dev/urandom -DNodeType=WebUser -Djdk.tls.ephemeralDHKeySize=2048 -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -Dignore.endorsed.dirs= -classpath /usr/local/tomcat/bin/bootstrap.jar:/usr/local/tomcat/bin/tomcat-juli.jar -Dcatalina.base=/usr/local/tomcat -Dcatalina.home=/usr/local/tomcat -Djava.io.tmpdir=/usr/local/tomcat/temp org.apache.catalina.startup.Bootstrap start
For the other system if I startup pega on tomcat (non-docker), connect to the database I can login and change the password. Thereafter when I startup pega docker again I can login and see dev studio. However, if I switch to admin studio I get the following error:
Status:fail
Very strange indeed, could be the OS is missing some libraries, but we have been using this image without any issues, check this link (the last answer) - maybe you can give it try by installing missing libraries in your docker image: https://askubuntu.com/questions/674579/libawt-xawt-so-libxext-so-6-cannot-open-shared-object-file-no-such-file-or-di
Also, can you try this image which already has prweb.war baked in: https://hub.docker.com/r/pegasystems/pega
# curl -s http://$(hostname -i):8080/prweb/PRRestService/monitor/pingservice/ping | python -m json.tool
"health": [
"last_reported_time": "2019-10-07T17:51:51.900Z",
"status": "success",
"test_name": "HTML-Stream-Check"
"test_name": "Streamservice-Check"
"node_id": "xxxxxxxxxxxxxxxxxxxxxxxxxxx",
"node_type": [
"WebUser",
"BackgroundProcessing",
"Search",
"Stream"
"state": "healthy"
Kevin,
