Charlie
ID
Last activity: 17 Oct 2019 21:04 EDT
Can We Change Authorization endpoint on OAuth 2.0
Is it possible to change the URL in the Authorization endpoint that is automatically generated by the system?
because when I log in to the native application (APK), I get the following error
{"errors": [{"ID": "unsupported_shceme", "message": "TLS should be enabled."}]}
or is there other input for this problem?
Thank you
Charlie
If you already uses https now (in Pega platform), can you recreate the channel? System should use the user login http protocol. You may need to rebuild your APK.
