SG
Last activity: 1 Oct 2019 23:39 EDT
Connect pgAdmin to Pega Database on Pega VM
Issue:
Recently i had an issue while trying to connect pega database on pega VM to pgAdmin .
Solution :
There are 2 configuration files in /var/lib/pgsql/9.4/data folder within VM , where you might have to make changes to successfully connect .
- postgresql.conf - confirm -> listen_addresses=’*’
- pg_hba.conf - add -> host all all Proprietary information hidden/0 trust
Please see the screenshot for changes made on pg_hba.conf
Once the changes are made restart postgres server.
Note: if you are using Pega Academy VM , below are the credentials .
VM Console Login Credentials:
- User Name: root
- Password: install
Now able to connect pega database from VM to local pgAdmin below :
PostgreSQL Database Info and Credentials
User | Password | Description |
postgres | postgres | Process owner for DB and Sys DBA |
pega | pega | Pega Sys DBA |
***Moderator Edit-Vidyaranjan: Updated content to remove proprietary information ***
