John Deere
Last activity: 9 Sep 2019 4:02 EDT
How to validate date using when rule
I want to write a generic parameterized when rule which should accept the parameters from Data Transfrom and check whether the date is in valid format or not. if the Date is not in valid format then it should not set the date field(Generally if the date field is blank pega will take the default date as 01011970).
Can you please let me know how can this be achieved?
Thanks.
Yogesh.
