Deployment Manager FAQ and Troubleshooting guides
This article is now out of date. The latest content regarding Deployment Manager FAQ can be found in Pega community at the following link: https://community.pega.com/knowledgebase/articles/devops/86/frequently-asked-questions-faqs
Please refer to the link above for the most up-to-date content.
Here is a list of all the general FAQ and troubleshooting guides. This will be a master list that will be updated as new FAQs are added here over time.
Frequently Asked Questions
- Installation and configuration
- Deployment Manager Versions and Installation
- What versions of the Pega Platform is required by Deployment Manager?
- Can cloud customers directly download new releases from Pega Marketplace?
- Where can I get older versions?
- What is the preferred configuration for installation?
- Can my candidate environments exist in different VPCs?
- Can a single system serve as both a development system and an orchestrator?
- What is the recommended size and configuration for the orchestrator instance?
- How should operators be configured on the orchestrator?
- Application Structure and Configuration
- Pipeline Modelling
- Artifacts and Repositories
- Can I use Deployment Manager without hosting an artifact Repository?
- Why are there two repositories being used in the pipeline?
- Are custom repository types supported?
- Is the Pega repository type supported?
- Is the defaultstore repository supported?
- What repository should I use on Pega Cloud?
- Can I use a Source Code Manager (SCM) as a repository?
- How are artifacts generated over the course of a Deployment?
- Continuous Integration and merging branches
- Other
- How to guides
- Installation
- Submitting changes through Branches
- Deployments
- Running tests
- Other
- Troubleshooting Guides
- Troubleshooting connection issues between Orchestrator and Candidate system, or vice versa
- Troubleshooting email configuration
- Troubleshooting errors on the Merge Wizard
- Troubleshooting trigging the CI process using branch publish (deprecated as of version 4.4)
- Debugging Jenkins integration with Deployment Manager
- Common Problems
- Task Specific
- Merge request shows an invalid password error when trying to merge
- Stuck merge requests
- Merge requests fail, indicating that a branch could not be found
- When I merge I see “Insufficient privilege” error in the merge requests modal
- Branch merge task fails with an error
- Merge shows an internal error even though merge was completed
- Pipeline Diagnostics and Intersystem Communication
- My 8.1 Orchestrator is very slow or unresponsive on cloud.
- On Pega Platform 7.4 my orchestration system fails to connect to managed systems.
- Pipelines and diagnostics failing due to outdated Orchestrator URL
- After upgrade deployment manager to 4.5, repository diagnostics is failing with error 'The artifact cannot be read from the repository'.
- Other
Other resources
- Comparing Deployment Manager vs open DevOps tools such as Azure DevOps, Jenkins, Bamboo and others
- Ask the experts session on Deployment Manager with Linoy Alexander
- Ask the experts session on DevOps & Deployment Manager with Ryan Feeney
