Connection to TeraData Database
Can someone tell me how to connect to Teradata data from Pega
Pega uses jdbc connection to all external database, you would need to download the jdbc driver file for TeraData (https://downloads.teradata.com/download/connectivity/jdbc-driver) and follow the steps like this:
https://collaborate.pega.com/discussion/how-configure-external-db-connections-designer-studio
Good luck!
Can i use the same process to connect to Pega cloud environment also?
I need to connect to Teradata sql Assisstant 15.10.05 version .But in the above link i couldn't see this version driver files.Is there a way to get for the version which i need?
Lakshmi.
This is an entirely different use case. You can connect to Teradata from Pega (on-prem or pegacloud) through what I mentioned above. Teradata sql Assistant is a client connecting directly to Teradata. No Pega is involved in this case. What exactly are you trying to accomplish here?
