where will get the details of this function "pega.getServiceUtilsPriv()"
we are facing some issue in integration, so on debugging the issue we found below code in OOTB activity, so wanted to understand the function behavior of "pega.getServiceUtilsPriv()" in below code-
final com.pega.pegarules.priv.util.ServiceUtilsPriv svcUtilPriv = pega.getServiceUtilsPriv();
final ClipboardPage stepPage = tools.getStepPage();
final ParameterPage pp = tools.getParameterPage();
final ServiceUtils svcUtil = tools.getServiceUtils();
final String DEFAULT_ENCODING = "UTF-8";
// final java.util.Map resourceParamValsMap = (java.util.Map) pp.getObject("pyResourceParameters");
try
String serviceURL = svcUtilPriv.getStringIndirect(stepPage, "pyResourcePath");
final String overrideSvcURLWithThis = tools.getParamValue("EndPointURL");
if (overrideSvcURLWithThis != null && overrideSvcURLWithThis.trim().length() > 0)
serviceURL = overrideSvcURLWithThis;
if (serviceURL == null || serviceURL.trim().length() < 1)
final String val = "Fail:Missing";
final String msg = "service URL was not provided";
oLog.error(msg);
pp.putString("pyStatusVal", val);
pp.putString("pyStatusMsg", msg);
throw new ConnectorException(msg, handlerFlow);
try
oLog.error(msg);
mainURLBuilder = new StringBuilder(serviceURL);
catch (ConnectorException ce)
// handles inbound and outbound mapping exceptions...
throw ce;
catch (Exception e)
// need to wrap this in a ConnectorException
String val = "Fail:InternalReason";
String msg = "Caught unhandled exception while getting Service URL: " + e.toString();
oLog.error(msg, e);
throw new ConnectorException(msg, handlerFlow, e);
finally
LogContext.pop();
//Sanity check of stopping detail timers
if (svcUtil.stopConnectOutMapReqTimeStat())
oLog.warn("oConnectOutMapReqTime timer stopped in finally block, timer will not be accurate");
if (svcUtil.stopConnectClientResponseElapsedStat())
oLog.warn("oConnectClientResponseElapsed timer stopped in finally block, timer will not be accurate");
if (svcUtil.stopConnectInMapReqTimeStat())
oLog.warn("oConnectInMapReqTime timer stopped in finally block, timer will not be accurate");
