Deutsche Telekom Services Europe SE (DTSE)
DE
Posted: Apr 25, 2019
Last activity: May 8, 2019
Last activity: 8 May 2019 10:45 EDT
Purge / Archive rules
Hi.
Can someone give me a short overview about the relevant rules from the purge / archive functionality, which are responsible for the evaluation of the data which is purged / archived.
I would like to check on which criterias the attachments to a case are evaluated.
Thanks & regards, Matthias
Work item data volume can grow to a size where hundreds of megabytes of database storage is required. The Purge/Archive wizards enable you to use an agent to automatically delete old work item data from the respective tables or store them in archive files. Purging and archiving old work items and their related history and attachment records helps maintain system performance by reducing database processing demands.
You can refer following link also which will give more information on this.
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#tools/purgearchive/aboutpurgearchivewizard.htm
