TCS
Last activity: 4 Mar 2021 1:12 EST
Can we use savable datapage to insert entry into the local table?
Can we use savable datapage to insert entry into the local table ,as savable page is having source of lookup will it insert the record in data table?we are trying to achive this with datapage but it is not happening.
Could you please give some suggestion.
Likes (1)
Chinmayee Parija -
Yes, we can insert the data into any table
Please check the below link for more information
https://collaborate.pega.com/question/savable-data-pages-v74
Are you talking about storing the record into the data type using Savable data page?
Rabobank
Yes, Mahesh. Question is- Is it possible to insert the record into the table using savable data page. Because if we try we are facing below issue.
We are getting an error if we use Save Data Page with source as lookup when we try to insert a new record. Error Message "Can not find an instance in the table." because the Data Page is first trying to open the record and then update it on top of it but its not inserting a new record. Please provide additional information on this.-
Regards
Gouri Shankar
Lloyds Banking Group
The post doesn't say if we can Insert a new record using Save Data Page if the source of the data page is Lookup. We are getting an error if we use Save Data Page with source as lookup when we try to insert a new record. Error Message "Can not find an instance in the table." because the Data Page is first trying to open the record and then update it on top of it but its not inserting a new record. Please provide additional information on this.
Rabobank
Hi, i have same question, did you find the answer for this?
Gouri Shankar K
Hi @GouriShankarK,
No we did not get an answer for this and now we started using 2 different data pages one to insert record to table with data source set to dummy data transform and another D_ Page to retrieve the record using a lookup list. Please let us know if you find a different approach.
de Volksbank
Hi, Thanks for response, i used activity to do this, but i would like to use savable D page, if it is possible.
Regards
Gouri Shankar K
Coforge DPA Pvt Ltd
Not a good idea but.. If you really want to do this, call activity in data save options and use Obj-Save method.
@Vishakha Use the same savable data page remove the lookup and keep source as data trasform map the properties in the datatransform you want to insert into the data type.
Naazneen haseen rubina Mohammed Ghouse Rafael Cuevas Mijangos
