Ernst & Young Business Advisory Solutions SA
JP
Last activity: 3 Apr 2019 8:42 EDT
How to use declare triggers without causing any problems
We would like to use declare triggers without bad effects.
We implemented 2 declare triggers and 2 activities which is related to the declare triggers.
One trigger(trigger A) is created on Class"Rule-" and logs regarding privilege works, like modifying translation files, editing decision tables, etc... .
Another trigger is created on Work class, and logs operator works, like creating cases.
We found that trigger A prevented creating new decision tables.
Reproduce steps;1.Designer Studio>App>Decision table>create
If trigger A is unable, we can create it correctly.
Now, trigger A is unable as it is sure to make bad effects to our system.
Is it deprecate to create declare triggers on Rule- class?
Could you teach me how to create logger activities without bad effects?
I never tried myself to create Declare Trigger at Rule- level.
Can you clarify what the activity is actually doing? Could you add a screen shot?
