Pega Robotics Differentiators
Kindly share inputs for differentiators
Show More
| Blue Prism Ver (6.3) | Pega Robotics 8.0 | |
| Bot Types | Supports only unattended automation | |
| Licensing Model | More Flexible | |
| Multi Tenancy | Added the multi-team environment feature in v6.3 which enables customers to create multiple teams with varying levels of permission and access to Processes, Objects and Resources |
| Ease of Development | Lower as compared to UiPath & AA with no recording feature and | |
| Security Features | BP scores slightly higher on this | |
| Event Based Triggers | BP does not provide event based triggers. | |
| Version Control Integration | No native integration with Third party tools. | |
| Work Queues | Available since inception of Tool | |
| MI Reports | Out of box reporting features available like reporting tables, scheduled job to populate schema with standard dashboard. | |
| Cognitive Roadmap | BP is relying on external partnership like intelligent system and also offers VBO to integrate with Google, IBM Watson & Microsoft Cognitive services. | |
| Windows 10 Support | •Fully Supported | |
| Architecture | •Bot Exe interacts with App Server Exe through WCF (TCP/IP) protocol and .NET Remoting. | |
| •All communication can be secured using certificate based authentication | ||
| •App Server Connects to DB | ||
| Code Files | •Source Code files stored in SQL DB | |
| •Bot extracts code from DB while execution happens on Bot VM | ||
| Configuration Management Integration | •Source Code stored in DB hence no out of Box integration with CM tools like SVN possible. | |
| •Provides inbuilt version control mechanism which offers limited features. | ||
| Credentials Vault | •Inbuilt credentials vault to store third party credentials encrypted using latest algorithm in file share. | |
| Encryption Algorithms for storing Credentials | •Offers Multiple Encryption Algorithm. | |
| •provision to utilize manual or automated generated Key. | ||
| •Provision to store key manually and add custom Access restrictions. | ||
| Communication | •Bots access credentials decrypted at App Server. | |
| •Shared with client in plain text through secured channel (WCF using TCP\IP Protocol or .NET Remoting) | ||
| CyberArk Integration | •Out of Box Cyber Ark Integration available | |
| Work Queues | •Provision mechanism to utilize Encryption Algorithm to encrypt & store Work Queues items in databases. | |
| Ability to Run Bots with locked Desktop | •Bots need to unlock desktop\VM, provides Log In Agent functionality to execute own its own. | |
| Work Queues Supported | Work Queues available since inception of product | |
| Item level Locking | Available | |
| Defer Until / Postpone Item Processing | Available | |
| Encryption of WQ items | Available | |
| Tagging to filter items | Available | |
| Retry Feature to process items marked as Exception | Available | |
| Ability to Mark Exception Programmatically | Available | |
| Filter Queues Programmatically | Available | |
| Priority Assignment at Item level | Available |
Show Less
Hello Rohit, as noted in your previous post. It would be advised to talk to your Account Executive for detailed information regarding the differences between Pega Robotics and Blue Prism, etc.
