Param value from Data Transform cannot be accessed from Activity
I am using an activity named "ABC" and use the Apply-Data transform step. Inside the data transform named "XYZ transform", I do some data processing and result "true/false" assigned to Param.test.
When that Param.test is accessed from the activity "ABC" and set in another step Property-Set, which is always empty. May I know how can I access Param value in Data Transfrom from Activity.
Thanks and Best Regards,
Aung
